Navisworks General Discussion
Member
0 Kudos
Post 1 of 5
NWC/NWD Exports to Wrong File Unit
389 Views, 4 Replies
11-09-2012 01:14 PM
We are having issues when creating and NWC or NWD from AutoCAD. Our drawings are are done in mm, but the results of about 1/3 of our exports are coming out as inches. We have the following settings:
In Drawings-
Units = unitless
NWOPT-
    Interface - Display units = mm
    File Readers - DGW - Default Decimal Units = mm
In Navisworks Simulate-
Global Options-
    File Readers - DGW/DXF - Default Decimal Units = mm
Are there any other settings that need to be checked that would cause our exports to be set as inches? We are using AutoCAD 2011 SP2 and Navisworks Simulate ver. 8.1.0.64656.
Employee
9 Kudos
Post 2 of 5
Re: NWC/NWD Exports to Wrong File Unit
11-12-2012 12:23 AM in reply to: bmrob
The DWG exporter defaults to Inches if the DWG database units (equivalent to the LUNITS system variable at file save time I believe) are set to Engineering or Architectural (i.e. 3 or 4). Otherwise, it does use that option.
Hope that helps,
Jeff
Senior Software Engineer
Navisworks
Autodesk Ltd.
Member
0 Kudos
Post 3 of 5
11-12-2012 01:56 PM in reply to: JeffH_ADSK
Thanks for the reply Jeff. I checked several of the drawings and the Drawing Units Type is set to Decimal.
Employee
9 Kudos
Post 4 of 5
11-15-2012 03:49 AM in reply to: bmrob
The only other code in the exporter that sets units is some ADT/ACA specific code that looks at ACA's definition of linear units. Are you using ACA (or a vertical thereof)? Is it possible ACA's own definition of units differs from the usual AutoCAD one? I'm afraid I don't know the ACA UI well enough to point out where such a linear unit setting might be set. You could also try turning off the ADT support in the exporter under the Advanced menu in the exporter's Options to verify this.
Hope that helps,
Jeff
Navisworks
Autodesk Ltd.
Member
0 Kudos
Post 5 of 5
11-19-2012 12:17 PM in reply to: JeffH_ADSK
We aren't using ADT/ACA, the only other software we are using is ShipConstructor 2012 R1.2.
Have API Questions?
New Dedicated Forum for Navisworks API
