We have one workstation where Navisworks simulate will not open .nwf or .dwg files. When rying to open either file type an error message displays relating to a specific file - lcdbx2007.dll.
I have tried a repair install, full reinstall, and also through Windows full uninstall and re-install from scratch; results remain the same.
The software can open .nwc files, but this is not sufficient as then the end user cannot be sure he's looking at the latest version. The same software was functioning normally on the PC yesterday, nothing else apparent has changed.
Copy of the error message attached.
Hello. The file you are trying to load, does it have any 3rd party objects in it? Does it require and object enabler? What is your loader year set to in your Options window? You are trying to access the 2007 loader in this error message. Set it to a different loader year and try to open the file(s).
Have you tried to reinstall or repair the .NET environment? Have you tried using a different user profile?
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
Hi there,
It is likely that there is some conflict on the machine preventing lcdbx2007.dll from loading e.g. a missing dependency DLL. In such a case, usually there are several different copies of a given DLL on the machine, Navisworks needs a specific version, and now for some reason it's not finding it.
In addition to what David has mentioned, here are some other things to try:
Hope that helps,
Jeff
