Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
NW Mirrors parts from IFC
6 REPLIES 6
alex_busov
1509 Views, 6 Replies
Good day
Have in example one metal part and another one is just mirrored on X axis in Allplan.
When i import it in Navisworks, it also mirrors it in Y axis direction.
In free IFC viewer DDS-CAD all is OK, both part are just mirrored on X axis.
Never use mirror command if i want to import IFC to NW? 😞
P.s. IFC made from allplan, this metal parametric parts = alplan's smartparts.
And if i export it to DWG, all is ok, just problem with IFC.
Thanks in advance,
Alex Busov
6 REPLIES 6
lee.mullin
in reply to: alex_busov
Hi Alex,
I've logged this with development. Not quite sure what is happening, hopefully we can get this resolved in a future release.
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
alex_busov
in reply to: lee.mullin
If it's possible, please write where is the problem is borrowed.
As far as IFC is almost just a text file, we can try to manually write a script to correct such objects/files.
if we could know what happends to them.
Thanks a lot.
alex_busov
Also importing to Acad Mep with "IFCImport" command gives non mirrored parts as we need.
Seems to be something with Navis :(.
P.S.but in AMEP some info looses on other parts...
lee.mullin
Removing the lines below resolves the problem, editing the IFC file would have to be at your own risk though.
#20097= IFCBUILDINGELEMENTPROXY('05AiV1NIn39QVzibYnDMtx',#4,
'\S\L\S\M-553-1',$,$,#20087,#20075,$,$);
Lee Mullin
Autodesk Ltd.
alex_busov
Very pity, but it doesn't help.
Removing that string gave that one part just disappeared in NW and in tekla bimsight.
In Autocad MEP, DDS-CAD viewer example.ifc with deleted string don't even loading
The problem seams to be somewhere deeper.
In attachments how "example.ifc" from my first post looks in different applications: Tekla BIMSight, DDS-CAD viewer, Navisworks.
lee.mullin
Thanks Alex, that workaround seemed to resolve the problem for me. It is with development and we hope to resolve this in a future release. For now however there is not much more we can do until there are changes in the product.
Lee Mullin
Autodesk Ltd.
Rail Community
