Revit 2015 R2 Exporters - Our attached Autocad files in Revit 3d views do not export any more with 2015. What setting needs adjusted as this is required for our workflow and has been working fine with 2013 and 2014, so there must be a new settings that we are unaware of.
Workflow:
1. Revit 2015 R2 3d views with linked 2d Autocad Files
2. exported using Navisworks R2 exporter
3. no line work transfers to Navisworks 2015 Manage, only the revit and linked dwg solids.
4. We have changed the convert linked file select box - it doesn't correct the issue
we need the 2d line work
Thank you for your post. In this case there is a known issue with this feature and there is an article written about the current feature and this limitation. I have included this below. In this you will notice there is a workaround listed and will help navigate this issue. Please review and apply. Thank you.
Exported views are missing the linked files: http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
If we have misunderstood anything whatsoever, please let us know so we can best help where possible.
In addition to this, I have also included a development product feedback link below. Please navigate tto this link to submit feedback on this current feature and the business impact of this limitation in your day to day software navigation. This will help build momentum in any future changes from the development team. Thank you.
Software Feedback: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
NW manage 2015 has been very Disappointing, this adds another item that it now can't do correctly as advertised. All these solutions double the steps, managing, and checking on everything we produce out of Revit. Navisworks Manage 2014 was the last actual usable version for firms like us that have 15+ Revit users + Navisworks Manage and produce construction documents.
