Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Not able to set DWG Loader for 2007 with Navisworks Simulate 2013
1 REPLY 1
366 Views, 1 Reply
Not able to set DWG Loader for 2007 with Navisworks Simulate 2013 on a workstation running Windows 7 x64 and no AutoCAD. The DWG Loader versions stop at 2008.
I'm trying to open ADT 2007 drawings.
On a XP SP3 workstation with ADT 2007 and Navisworks Simulate 2013 the DWG Loader allows for teh selection of 2007.
1 REPLY 1
JeffH_ADSK
Hi there,
On 64-bit Navisworks, there is no support for AutoCAD 2007 Object Enablers as AutoCAD only added 64-bit support in AutoCAD 2008. 32-bit AutoCAD & RealDWG are not supported on 64-bit operating systems, and thus Navisworks only offers 64-bit DWG handling.
The alternatives available are to use the 64-bit 2008 (or higher) Object Enabler for the relevant DWG file, or to export on the 32-bit CAD application & machine to NWC & load the exported NWC on the 64-bit machine. The DWG file format itself is 32/64-bit agnostic so as long as you can use the relevant Object Enabler, compatibility should remain. The ADT/ACA OE is included as part of the Navisworks installation, so the file should load correctly without additional installation.
Hope that helps,
Jeff
Senior Software Engineer
Navisworks
Autodesk Ltd.
Rail Community
