Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
NM 2015 Timeliner Export w/AutoDesk Renderer
4 REPLIES 4
sureshchotrani
502 Views, 4 Replies
Hello guys,
When I export Timeliner with Autodesk Renderer, I am not able to see dates, activities running, etc..
Do you guys have any idea why is it not showing this with Autodesk Render.
Suresh C
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
4 REPLIES 4
dgorsman
in reply to: sureshchotrani
You mean, the date-time-etc. string is missing from an MPG/AVI/etc. movie file?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
sureshchotrani
in reply to: dgorsman
Yes, when I follow attached while exporting, NM2015 doesn't show date-time-etc.
But when I select Viewport for Renderer option NM 2015 shows all whatever I require.
Suresh C
dgorsman
This is a well known and long-time shortcoming of the Timeliner.  The date-time information is overlaid onto the viewport (using OpenGL, if I remember rightly).  The rendered output is done differently so there is currently no way to get that information directly into an exported movie file.  You would need to overlay your own text using post-processing software; among other benefits, getting overlay text synchronized with the movie is much easier when rendering to frames rather than straight-to-video.
adeshk112
Hi Suresh.
I faced the same problem and found the Solution for the same.
When you export the Animation, in the Render Option, Select "Viewport" and then export it.
You will get all the Overlay Text Data.
This worked in NW Simulate 2014.
Hope this helps.
Thanks.
Adesh K
Rail Community
