Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navisworsk 2013 randomly crashes amdist opening NWF
1 REPLY 1
audiocycle
298 Views, 1 Reply
I have a File Set (NWF) consisting of a variety of DWG, NWC & NWD files from other trades I am coordinating with on a certain project. The NWF will randomly crash at various points of utilization of the file. Sometimes upon opening the NWF & at other times upon refreshing due to changes that I make to my DWG file.
Autodesk reports have been generated & reported each time & I have yet to get a response from Autodesk. This is very frustrating as a the end-user.
Anyone have suggestions to help troubleshoot the issue?
Barry
Tags (3)
1 REPLY 1
- append all files using UNC paths (\\server\share\Path\file.ext
- before opening the NWF, delete all NWC's so that they are recreated
- check the performance settings to close all files on opening
- use the most recent version of Navisworks: if you have to deliver a 2013 NWD, you can use Navisworks 2015.
- check that the NWC andNWD files appended are either saved in an older version (2014 if you are using an 2015 NWF) or with the exact same Service Pack and hotfix.
- use a 64bits machine with 8GB of 16GB RAM if your project gets bigger
Rail Community
