Navisworks General Discussion
New Member
paulgs06
Message 1 of 4 (492 Views)
Navisworls 2013 Item Proprties for PDS Piping models.
492 Views, 3 Replies
09-21-2012 06:43 AM
Navisworks 2013 does not display PDS Component data for PDS piping models (MicroStation v7.0 dgn files), even though it appears to be reading the tag (.drv) files. It does display data for equipment models and strurtural models.
Has anyone experienced this?
Valued Mentor
Patrick_Aps_9121
Message 2 of 4 (460 Views)
Re: Navisworls 2013 Item Proprties for PDS Piping models.
09-25-2012 01:50 AM in reply to: paulgs06
not exaclty,
but when you use the Selection Tree -> Properties -> PDS component data
and you click a + sign,
all flavours of Navisworks 2013 crached.
Perhaps this is solved with ServicePack 2, but for PDS data, I remain on the 2012 versions.
New Member
paulgs06
Message 3 of 4 (409 Views)
10-05-2012 09:03 AM in reply to: paulgs06
I did find a workaround. If I deleted the PDS tag files for piping (*.drv) and recreated them, then the data appeared in Navisworks. Don't know why this occurs.
Valued Mentor
Patrick_Aps_9121
Message 4 of 4 (390 Views)
10-07-2012 10:40 PM in reply to: paulgs06
Did you delete the NWC files of those models also ?
I had the expericene in the past that when DGN files did not change of date, but DRV files did, then NWC were not updated and PDS data was not showing up. In this scenario, deleteing the NWC files then re-create the drv files and then opening the NWF file to force the recreatuion of NWC files did the trick.
Have API Questions?
New Dedicated Forum for Navisworks API
