Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navisworks Switchcack Failure
3 REPLIES 3
blonds
507 Views, 3 Replies
I love Switchback and have found it to be a valuable tool of coordinating Revit and Navisworks. I have gotten used to some basic errors of Navisworks timing out during the Switchback process, but nothing too extreme.
 I have encountered my first major problem in my new project. When I click Switchback, nothing happens. No error message and no result. The plumbing.nwc cache file is created from a 3D model in a Revit file (Project 2). This 3D model is from a linked Revit file (Project 1) Thus the workflow: Project 1.rvt --linked-->Project 2.rvt--exported as nwc-->Navis file.nwf
Both Revit projects have been activated for switchback (Add-Ins_External Tools_Navisworks Switchback) Nothing is occurring. I assume the Navis file must not be properly going to Revit to display the pipe I wish to Switchback. My first Switchback attempt gave an error that asked for the file location to be resolved. I corrected this (or so I believed) by changing to location from my boss's local file to my own and re-exported the cache file from my local copy (Project 2). I made the switch but have not seen any more errors.
 Still no luck. Is there a way I can check what project it is trying to go to? Any other solutions? Any information would be much appreciated.
S.
Tags (1)
3 REPLIES 3
lee.mullin
in reply to: blonds
Unfortunately this is a limitation of Switchback at the moment. We have an enhancement request in with development to support Switchback of Linked files.
Unfortunately the workaround at the moment would be to work with these files individually.
Please let me know if this answers your question.
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
BIM_Cardial
in reply to: blonds
Hi !
Have you installed the Service pack 1 ?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17757207&linkID=10382102
I saw the same problem with a friend and they didn´t install the SP 1 too.
After they do this, I send you a reply, or you could do the same.
regards,
Ricardo Cardial
Ricardo Cardial
Arquiteto Urbanista - Mentor BIM
BIM | Nuvem de Pontos na FARO do Brasil
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta
Clique em Curtir se gostou.
Autodesk Community
blonds
in reply to: blonds
Thank you Lee and Ricardo. Since your messages I have installed the Service pack and tried to work with the individual Revit files and cache files but have still not had full success. I no longer fail to get a response from Switchback. The new development is the response I do get is fatal error.   I'll let you know if I have further developments, but I think the best I can do now is to continue to work with the individual files and how they are being read into Navisworks.
S.
Rail Community
