I'am running into this problem every day now. I CAN append a file in NavisWorks, but no objects are showing up at all!! It only works if i do a NWC-OUT then i'm able to append that file into my model.
I tried cleaning up the DWG, doing Purge, and Audit. And still nothing. I also tried cutting the file size down to see if its performance issues, beut even that is not working.
I'M LOST!!!
Advanced thank you if someone replys with a solution.
Thanks.
Navis User.
Is this a plain AutoCAD DWG or was it created with another application e.g. AutoCAD Architecture? Also do you know which version?
It may be worth trying the File Reader settings in Options. Particularly the Loader version and Render settings.
I am also having this problem with this. If I set it up to convert xrefs with the dwg it shows up. But if I try to append the DWG seperate Navisworks they wont show up.
