Problem :
Appearance Profiler is not updating the color / transparency changes on the newly added items in the model files
Description :
a) We are using navisworks session (.nwf) for our model review on a daily basis
b) We have created search sets and appearance profiler sets ( for color updates)
c) The PDS model files are getting updated on a daily basis to the review session
d) New items added to the model are captured by the search set conditions
e) Search sets are used in the appearance profiler for color changes
f) Color changes are not happening automatically , ie we have to click run on the appearance profiler form to update the color to the new items added in the model
Solved by arief.rahman. Go to Solution.
How do you run step A ?
I do it with a VBS script based on the AUTO_08 example.
it includes the use of selection sets:
set selsets = roamer.state.SelectionSets()
count = selsets.Count
for i = 1 to count
set current = selsets.Item(i)
' check the name
if current.name = "AutoPlant Insulation" then
'override transparency
roamer.state.overridetransparency current.selection, .5
end if
if current.name = "PDS Piping Insulation" then
end if
next
You can refere tot his following article below :
http://beyonddesign.typepad.com/posts/2012/07/search-sets-vs-selection-sets.html
http://beyonddesign.typepad.com/posts/2011/06/project-templates-for-clash-detective.html
also this blog below :
http://bimnewworld.blogspot.sg/2011/01/search-and-selection-sets-part-i.html
http://bimnewworld.blogspot.sg/2011/04/search-and-selection-sets-part-ii.html
regards,
