Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navisworks Simulate 2013 (from InfDsgnSuite) crashes when loading C3D surfaces
0 REPLIES 0
Message 1 of 1
dlconsulting
695 Views, 0 Replies
I'm using the Infrastructure Design Suite 2013, with Civil 3D and Navisworks Simulate and the required Civil 3D 2013 object enabler.  Everything is 64-bit.  I can load DWG files with 3D content just fine, but as soon as I try to load any file with a surface, I get a series of fatal errors:
FATAL ERROR: Unable to load file 'AcTcUiRes.dll".  The specified module could not be found.  Press OK to abort.
... followed by...
acui19res.dll not found
... folloed by ...
AnavRes.dll not found
If I use NWCOUT and save the file in NWC format, it imports fine.  Any suggestions appreciated.
Dan
0 REPLIES 0
Rail Community
