Navisworks General Discussion
Distinguished Contributor
BrettCaldeira
Message 1 of 6 (1,484 Views)
Navisworks Review or Manage will not Uninstall!
1484 Views, 5 Replies
11-17-2009 11:06 PM
Good Day All
Im looking for a clean uninstall method for removing Navisworks! For Some reason I cannot uninstall Both Manage or Review. We have network licenses for both products so I have both have been installed. When trying to uninstall Navisworks Review from my workstation I get an error before the setup initilization started up stating that... NSIS Error - Installer integrity check has failed. Common causes include incomplete download, and damaged media...
When I try and uninstall Navisworks Manage on the same computer, setup initialization begins, then half way through the initiliazation I get the error: This action is only valid for products that are currently installed.
Both these errors on the same computer. Other software including AutoCAD seems to uninstall and reinstall?
Running windows XP Professional SP3
Any Help would be appreciated. Best Regards,
Brett Caldeira
Active Contributor
AndyG_ADSK
Message 2 of 6 (1,484 Views)
Re: Navisworks Review or Manage will not Uninstall!
11-18-2009 08:53 AM in reply to: BrettCaldeira
Brett,
For your Review, it sounds like the little utility that decides which language to present the setup GUI in is corrupt. You can work around this by going to your registry, open key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Autodesk Navisworks Review 2010 (32 bit) and copy the value of the "uninstall string" entry into a text editor.
So you will have a line looking something like this:
C:\Program Files\Autodesk\Navisworks Review 2010\setup\Uninstall.exe /P {CD4D81FE-EBDA-0000-B5BC-42988504F1F1} /M NW
Edit the line replacing "uninstall.exe" with "setup.exe", enclose the file path in quotes, and add /LANG en-US to the end of the line so you have something like:
"C:\Program Files\Autodesk\Navisworks Review 2010\setup\setup.exe" /P {CD4D81FE-EBDA-0000-B5BC-42988504F1F1} /M NW /LANG en-US
Then you can either save this as a batch script and run it or paste the line into Start->Run and run it from there. This should be enough to get the uninstaller up so you can uninstall.
Regarding your Manage uninstall, I would only expect to see that error message if you have uninstalled Manage except for some reason the installer has left behind the registry entries that make Manage appear in Add/Remove Programs. The thing to do would be to contact support and provide them with the installer logs from your Temp directory, and hopefully we can pin the problem down and give you a workaround.
HTH
Andy
BrettCaldeira
Message 3 of 6 (1,484 Views)
11-24-2009 05:37 AM in reply to: BrettCaldeira
Thanks for you Help AndyG. I got the review uninstalled.
I now have a problem on two other computers where it gives me the integrity problem. If I then run the registry startup, it comes back with an error that it cannot open setupres.dll. I cannot find setupres.dll in any of the instaltion paths. Nothing has been uninstalled, or attempted to be uninstalled. I think he problem comes in when you install both review and manage on the same computer. Only when I do this does the unistallation fail.
Do you have any Idea what I need to do to remove it from the workstation completely without using the uninstall.
Regards
Active Contributor
AndyG_ADSK
Message 4 of 6 (1,484 Views)
11-24-2009 07:39 AM in reply to: BrettCaldeira
Brett,
As a general rule you should always run an uninstall if at all possible.
In your specific case, it sounds like the language pack is missing. Go to Add/Remove programs, find your language pack for that install and try to run a repair on the lang pack itself. If you are using XP click the link in ARP for the language pack "Click here for support information" and choose repair on the resulting dialog. Try to uninstall Manage again.
If you do not have a language pack installed, then you will need to return to your installation disks and install x86\NAVMAN\en-US\NAVMAN_LP.msi (you should just be able to double click it). Now you should be able to run the uninstall for Manage.
HTH
Andy
BrettCaldeira
Message 5 of 6 (1,484 Views)
01-20-2010 11:23 PM in reply to: BrettCaldeira
Hi there Andy
I have a language pack in add remove programs but still can not remove Navisworks, I have also done repairs. I have 3 laptops doing this. I have attched the error message.
Active Contributor
AndyG_ADSK
Message 6 of 6 (1,484 Views)
01-21-2010 02:08 AM in reply to: BrettCaldeira
Brett,
What, if any, anti-virus software are you running? Any software firewalls? Did you install Navisworks from a download or from original media?
Andy
Have API Questions?
New Dedicated Forum for Navisworks API
