Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navisworks Manage 2016 will not start up
2 REPLIES 2
CCAMINOS0700
504 Views, 2 Replies
All of a sudden I get this error when I try to open Navisworks 2016
"The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)"
I have tried repairing and re-installing but still the same result. I also have Navisworks 2014 , it works fine.
Anyone see this error?
Carlos
2 REPLIES 2
Hi @CCAMINOS0700!
This error is usually caused when there is a mismatch of version number or if the .exe file is modified somehow after the installation. Have you tried a clean uninstall of Navisworks? Then please verify the build number is right for the latest update.
Let me know if this works, thanks!
Andrea K
Technical Support Specialist
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Andrea,
Thank you. It turns out I had an add-on that was causing this error. As soon as I uninstalled the add-on the error went away. I downloaded the latest version of the add-on and it was corrected.
Carlos
Rail Community
