Navisworks General Discussion
Member
david.mustyak
Message 1 of 4 (403 Views)
Navisworks crashes on MS Project import
403 Views, 3 Replies
07-18-2012 05:07 AM
Hi!
I'm using Navisworks Manage 2013 64bit. When i'm trying to add an MS Project data source through TimeLiner, the program crashes unexpectedly. The problem doesn't occur clicking on Primavera os CSV import.
Do you have any idea what could it be?
Thanks!
Active Contributor
ngombault
Message 2 of 4 (294 Views)
Re: Navisworks crashes on MS Project import
03-20-2013 07:30 PM in reply to: david.mustyak
I have the same issue. I tried re-installing MS Project, I also installed another version of MS Project (2010 64bits); I un installed and re-installed Navisworks... still crashing.
Did you find a solution?
Active Member
cjl0411
Message 3 of 4 (238 Views)
04-18-2013 07:59 AM in reply to: david.mustyak
Yeah. My problem is the same.. who can tell me what is going on...
Active Contributor
ngombault
Message 4 of 4 (232 Views)
04-18-2013 03:49 PM in reply to: cjl0411
I formatted my laptop a couple weeks ago, and the clean re-installation of all software works fine (Navisworks 2013 64bits & office 2010 64 bits (including MS Project).
I understand that formatting the machine is not a solution everyone would be ready to go for, but it shows that the issue comes from the order of installation and/or the number of different versions successively installed and un-installed. There might be a way to clean the registry from some key, either Navis or MSP to avoid reformating.
Have API Questions?
New Dedicated Forum for Navisworks API
