Hello, could someone please explain to me how and if Navisworks Manager automatically determines if a perviously identified clash becomes "Resolved"? Is this something Navisworks can do by somehow comparing 2,3,4.... iterations from updated Revit models? Or is this just simply a manually input selection by the clash detection coordinator? Thank you in advance for setting me staright on this! Aaron
Solved by IanBadcoe. Go to Solution.
Solved by dgorsman. Go to Solution.
Resolved clashes are determined by the unique IDs of previously clashing objects. In some cases, like with AutoCAD models, the unique IDs are regenerated each time the model is read so "closing the loop" isn't possible. I'm not a Revit guy but I *think* unique IDs are imported and preserved.
Ian,
Thank you for your clarification. My past experience with NW is to export a dwfx file from within Revit, but because I have not had proper training on NW Manage I am thinking that in order to do the "managing of clashes" as we have been talking about, there must be a different procedure. If what I am saying makes sense, can you please comment, and let me know what this procedure should be? Thank you!!! Aaron (Advance Design; AdvanDes)
Exactly. Preserving those unique ID's lets you run the clash tests over and over as the models are changed, and each clash is auto-marked as "Resolved" when no longer present. Then you have a history of not only where the problems are now, but in the history of the models as well. Clash detection is still possible without the unique IDs but it's less of a loop and more doing the tests from the start each time so there isn't any real history aside from any exported clash reports.
Speaking of which, I'll have to remember to submit something for this in time for the next AutoCAD BETA cycle. If we can get that unique ID handled in the core product it should propagate out to all the verticals as well.
Ok, I think I got it! I created a NWC file from the Revit Add-Ins>External Tools> NW 2015. Opened up the file in NWM and Created a Test clash and found 2 clashes. I then went back into revit and fixed the clashes. I created another NWC file (same name and overwrote the first one). Went back into NWM and could see that there was a warning symbol on my first clash test. I ran the test again...and voila, the two previous clashes came up "automatically" as Resolved...Cool! Thanks to all you guys who helped me out with this... Much appreciated!
I believe the key for this procedure to function correctly, is that the subsequent NW files have to all be named with the same name so that they will read from a Navisworks File Set file that was initially created. Please correct me if I am wrong on this. Thanks, Aaron
