Simple question:
Is there any way, ODBC or similar, to export parameter information OUT of Navisworks to either Excel or Access? I know how to use ODBC connections to bring additional data in, but as far as I can tell there is no way to export information out.
The closest thing is using the Quantification workbook export, but that is very limited in scope. Unlike if I was able to use SQL strings to selectively export items and parameter values.
I appreciate any responses, thank you!
Solved by dgorsman. Go to Solution.
You would need to use the API to iterate through the objects, harvesting data as you go.
Thanks for the quick response. I can uncross my fingers now; I figured that was the case, but I thought I would ask anyway.
(Unproductive complaining) Would an ODBC export function have been too much to ask?
Your description might be a bit off. "ODBC" is a method of connecting to a data source e.g. a database for additional information. Its not a means of extraction data from Navisworks or other programs, or creating a bill of material.
Speaking of unproductive complaining - I'm not too happy about providing QTO in Navisworks. Too much temptation to avoid getting the *actual* single-source-of-truth (design models), then blaming the model creators when the QTO reports don't match up with the properly generated ones.
