We import Point Clouds into Navisworks which always come in at the wrong angle, usually (2013) we just click on the cloud, hit Item Tools, Rotate, then set it somewhere so the front of the Point Cloud is the Front View of the ViewCube.
In 2014 however, when we rotate the Point Cloud, the ViewCube rotates with it... Surely this must just be a setting somewhere, or a View Lock... I've right clicked on the ViewCube and ensured that Lock to Selection is not enabled...
Can someone put me out of my misery?
Thanks all.
If you select an entire file and rotate it, then everything that was loaded with that file is also rotated - viewpoints, ViewCube orientation etc.
If you select part of the file and rotate it, then just that part is rotated.
Unfortuantely with a point cloud there is usually only one object in the file, so rotating it is the same as rotating the entire file. Right now, the only work around I can think of is to append in some dummy object (hide it if you want), save the point cloud and dummy object as an NWD, then you can open the NWD and rotate just the point cloud.
Thank you for replying with this. However, this definitely isn't the case for me in Navisworks Manage 2013.
If you look at the attatched images you'll see how I've rotated a single object without the View Cube rotating with it.
Is there a setting I need to change to prevent this happening in 2014? Seems odd that you need a work around for a task so simple in a later version of the software.
Thank you again,
This change in behaviour is due to a fix we made in Navisworks 2014. Now when you move an entire file all the related data (like viewpoints, world up orientation, etc.) moves with it.
There's no setting that controls this behavior but I have found some other workarounds that may work better for you :
1) If you're going to append the point cloud with another model, then rotate it after you've combined the models not before.
2) The view cube orientation is based on the information in Home -> File Options -> Orientation. You can set this data back to the original values after rotating the point cloud. You may also need to right click on the view cube and set current view as Home to get the Front face where you want it.
Thank you for the tips, I will try them out next time I import a point cloud.
On a similar note (this may have been covered elsewhere, sorry)... Is there a way to bring in the Point Cloud at the corect orientation/custom orientation so rotating the cloud isn't necessary any way?
First append a CAD file (a box or a floor drawin in AutoCAD or MicroStation or whatever)
Save the NWF file
Then start appending the Laser Clouds. Orientation should not change, as it is the first file appended that determines the orientation and units etc..
In my opinion, this is another example of a case where having "Template NWF " files would make sense.
Tim,
I am using Navisworks 2015. My model is comprised of several nwc files from revit. The model is in true north orientation so 42.22 degrees rotated off of view cube north. When I take a measurement the x and y dimensions are per the view cube orientation and are not orthogonal to my grid. I tried rotating the model to be aligned to project north or the view cube but when I did this the viewpoints I had set up were no longer intact. What method can I use to move the model or reorient the view cube so I can maintain my viewpoints and the x,y dimensions will report othogonal to my model?
