Is there any way to set the view in Revit when using switchback in Navisowrks? Previously in 2013, you would just get switched straight to the current veiw, now for some reason, you get sent to a plan view, then taken to a view called "Navisworks SwitchBack" this veiw is then set to the settings of the Navisworks view, so if in Navis you are in a perspective view, the revit view is set to perspective. I just want it to work like it did in 2013, 2014 is so much slower, and being in a perspective view in Revit is a total waste of time, I never work in perspective when in Revit.
