I am having trouble exporting a view from Revit 2014 to an nwc file. I continue to get an error that says "No suitable geometry found. Please check what part you want to export in the "Navisworks settings" menu.
After lots of searching, I have tried removing templates, changing the detail level, etc. to no avail.
When I go into the log file to see what the error is, I get this message,
Autodesk.Revit.Exceptions.InvalidOperationException: Rendering is currently not supported in the running instance of Revit. One reason for that to happen is that rendering and material libraries are not currently available.
at Autodesk.Revit.DB.CustomExporter.Export(View3D view)
at NavisWorks11.LcIRevitBase.Export3DView(View3D view_3d, StateDictionary state_dict)
at NavisWorks11.LcIRevitBase.ExportDocument(String& return_message, ElementSet elements, LcIRevitParameters* params)
This export error started when I updated Revit, do I need a new Revit Material Library? How do I make "the rendering and material libraries available"
Any insight would be greatly appreciated, thanks.
The revit file has some links??? If have links they dont show in Navisworks
You have to append all revit files (links) into Navisworks
