Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navisworks 2013 Corrupt Error
1 REPLY 1
Rcole
966 Views, 1 Reply
I receive the following error upon opening a NWF file.
 I am able to save the NWF but am unable to save or export a .nwd file and receive the following error.
Any ideas on what is wrong?
1 REPLY 1
JeffH_ADSK
in reply to: Rcole
The first error message means that Navisworks attempted to read in a given block of geometry from the file and that block failed to validate (most likely from an NWD). The second error message is a knock-on effect. We can't save out a new file with corrupt data, as we'd be saving out a corrupt file. The existing NWF can be saved because the specific block that is corrupt isn't saved into the NWF (it comes from a file that the NWF is referencing, and the NWF would still successfully save that reference).
Is drive N mapped to a network location? Do you get the same error if you try the same full set of files from your local hard disk?
There is a possibility that opening/saving over a network can yield corruption in translating the file between local memory & a remote location. We've had cases where opening & saving NWDs transfers the data in a different manner vs just copying the file & in that case the data can be corrupted during the network transfer by the time it reaches the local PC.
Hope that helps,
Jeff
Senior Software Engineer
Navisworks
Autodesk Ltd.
Rail Community
