Navisworks General Discussion
135 Kudos
Post 1 of 3
Navisworks 2012 Importers / Exporters for 4 flavours of Revit
804 Views, 2 Replies
05-31-2011 05:51 AM
We are trying to cut back on the products we support currently in house of our deployment images. The sheer size of server space used is phenomenal!!!
What i want to know is can Navisworks 2012 support Revit 2009 / 2010 / 2011 and 2012? Will the importers / exporters be compatible on all those versions? Or do i need Navisworks 2009 / 2010 / 2011 / 2012 deployment images also for the equivalent Revit versions?
I am guessing the method mentioned above is right, But i thought it would be safer to check? Also are there any known issues doing this?
If my post was helpful to you, please could you give "Kudos" and/or mark the "Accept as Solution" button(s) below. Thanks in Advance!
Duncan Brannan Send DuncanBrannan82 a Private Message
DuncanBrannan82,
Hello. Exporters are designed to be Backwards compatible. The 2012 exporters will install on 2012 Revit and prior versions down through Revit 2008. If you do not want to build a full Navisworks installation for the exporters, you can simply design your deployment to be only the exporters (smaller than the full deployment with teh program installed), or download the 2012 exporters separately and install them as needed. The lone exporter download is available here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=13947462&siteID=123112
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
Product Support
70 Kudos
Post 2 of 3
Re: Navisworks 2012 Importers / Exporters for 4 flavours of Revit
05-31-2011 08:40 AM in reply to: DuncanBrannan82
DuncanBrannan82,
David Dembkoski
David Dembkoski
135 Kudos
Post 3 of 3
06-01-2011 01:19 AM in reply to: DuncanBrannan82
David,
Many thanks for getting back to me! I suspected i was right and thank you for confirming this.
Duncan
Have API Questions?
New Dedicated Forum for Navisworks API
