Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navis Simulate unable to change pointcloud point sizes
6 REPLIES 6
937 Views, 6 Replies
Hi
  I have come across an issue which is happening on multiple PC's in our office where when a user tries to make the point sizes in navis bigger you make the number higher and it does nothing. we are using Navis 2014 and all service packs are installed.
It happens on diffrent drawings, I have already been advised to update video drivers on the PC but this hasnt helped.
Any help would be great thanks
Tags (2)
6 REPLIES 6
tim.wiegand
This is a known issue in the Autodesk graphics system that is the default in Navisworks 2014.
You can workaround this by switching back to the old Presenter graphics system (the default in Navisworks 2013). Go to Options -> Interface -> Display -> Graphics System. Uncheck Auto-select and change System to Presenter.
Tim Wiegand
Software Architect
Hi Thanks for the reply when I go to options then interface then display, I only have two avialble options Autodesk or drivers there is no such option
tim.wiegand
Once you've selected Display in the options tree you should see multiple sets of options on the right. Graphics System is the third set down.
Tim Wiegand
Software Architect
tim.wiegand
in reply to: tim.wiegand
Tim Wiegand
Software Architect
Thank you so much for your help means a lot ! do you know much else about navis I have an issue where the same drawing is being opened and on every pc it is opened on it crashes navis and says out of memory
tim.wiegand
Probably best to start a new topic for this issue so it doesn't get lost.
Tim Wiegand
Software Architect
Rail Community
