I've looked hi and low for this... what is the indication that 2014 SP2 has been applied? I presume it is a particular Version in Programs and Features. The readme does not address this... or I have overlooked it.
Solved by MichaelBussiere2. Go to Solution.
Thank you for your post. In this case the 2014 product did not list the version that would reflect update 2 was applied. I do apologize for this inconvenience. We have noted this with our development team and within the 2015 product it will now state what update is applied for tracking (under the product information-about). The update 2 applied to 2014 version should be 11.6.0.114420
I Hope this helps and again apologize on behalf of the team for this communication issue within our readme and product.
Well thanks for your reply. I did show that version number after the SP was installed.
However, I still do not see anywhere in the Service Pack documentation, readme or on the web page where you can download from what version you should see after the Service Pack is applied.
Am I just overlooking it?
