Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navis Primavera P6 SDK ODBC XE Connection
20 REPLIES 20
Message 1 of 21
granite07
2859 Views, 20 Replies
I'd like to link Navisowrks with Primavera but I get error messages 1) "No Primavera Data Sources Found", then 2) "Failed to connect to specified DSN data source Invalid User”, and then a popup states the server is busy. Primavera with the Oracle XE database is installed and works, and the SDK add-on is installed and has worked in the past. A quick check of the services looked like everything was running that was necessary. Any ideas?
Forest Peterson, granite@stanford.edu; build-sheet
20 REPLIES 20
Message 21 of 21
granite07
in reply to: peterayre
you are correct - I misread
it is the Activity ID that must have gaps between numbers to allow adding activities later, without breaking your links in Navisworks.
All of this is actually ridiculous, the database links need to work to allow using Navisworks the way it is intended - the rest of this discussion about c++ solution, XER plugins, and csv files are just bandaid fixes for what should work
Rail Community
