When we append the revit file into Navisworks the pipe fittings & Valves are not showing in line work instead of model as pipe or duct. So please suggest.
This is a kknow issue. Instead of loading the "Native" rvt file, run the nwc export in Revit and then appending to the NW Model, the fitting sand such will come in.
Mike
Thanks for your reply. But our question is why it is happening? Everybody wants to use the latest function in Navis 2013 which is directly appends the revit file into the navis. So what is your opinion?
Hello. I export the pipes from Civil3d to Navisvorks and get the artifacts. how to get around this problem? Thanks and sorry for bad english.
