Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navis export problem for pipe fittings & valves
4 REPLIES 4
BIMAbhi
1586 Views, 4 Replies
When we append the revit file into Navisworks the pipe fittings & Valves are not showing in line work instead of model as pipe or duct. So please suggest.
Thanks & Regards
BIMAbhi
4 REPLIES 4
in reply to: BIMAbhi
This is a kknow issue.  Instead of loading the "Native" rvt file, run the nwc export in Revit and then appending to the NW Model, the fitting sand such will come in.
Mike
BIMAbhi
Thanks for your reply. But our question is why it is happening? Everybody wants to use the latest function in Navis 2013 which is directly appends the revit file into the navis. So what is your opinion?
Thanks & Regards
BIMAbhi
Leonid_
Hello. I export the pipes from Civil3d to Navisvorks and get the artifacts. how to get around this problem? Thanks  and sorry for bad english.
Leonid_
in reply to: Leonid_
the problem is solved. Install Civil3d from IDSP.
Rail Community
