Navisworks General Discussion
Active Contributor
1 Kudo
Post 1 of 3
Navis and Google Earth
668 Views, 2 Replies
08-24-2012 07:35 AM
I do not fully understand the "output" options when trying to go from Navisworks to a KNL file for Google Earth...
I have 2 things I would like to do...
1. Use a google earth imiage as my "grade level plane" or an "underlay" as an image TO SCALE.
2. Be able to open up a Navisworks model in Google Earth --- The building is rather large and would like it to run smoothly - how do I "delete" or purge unused items? anyway to "gut" the building insides without using the Revit file?
I do NOT think the architect geo-locate the model on his end, however it is sitting about 300' above 'sea level'... in Navis the models all "float" about 300' off of Naviswork's 0,0,0
I have used the work around of exporting 3d .dwgs, loading sketchup, importing a "scene" from google earth, import the .dwg, and manually move the .dwg overtop where it needs to go in sketchup -- HOWVER, with large files this is just too ridiculous to even try to do on my computer. Sketchup does not play nice with these large files and cannot be worked with in Sketchup.
I have tried numerous searches on this; everything I find is that "it is an option" not a how-to or tutorial. Thanks!
Active Contributor
1 Kudo
Post 2 of 3
Re: Navis and Google Earth
08-24-2012 11:18 AM in reply to: tfischer
Ok, after messing around with it...
I Downloaded some surface planes from the Beyond Design Autodesk Blog...
I saved some views in Google Earth and applied them to the surface...
where I run into the problem is this:
The default surfaces are 1000m x 1000m... when I overlay the picture, it "stretches" the picture to fit the surface... how do I bring it in at 1:1 scale? I want to overlay my building over the site, and currently the background site picture is about 1.5x bigger than my building - i know you can scale this is Navis, but want this to be brought in 1:1 even if there are "grey" edges around the picture when placed on the 1000m x 1000m surface.
Active Contributor
1 Kudo
Post 3 of 3
01-30-2013 11:57 AM in reply to: tfischer
? Help?
Have API Questions?
New Dedicated Forum for Navisworks API
