Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
move the origin?
3 REPLIES 3
k.lew
5805 Views, 3 Replies
move the origin?
Is there any way to move the origin or set a designated coordinate system?
We're importing hundreds of Revit models into one Navisworks project.  We cannot move the files to the origin because of our constant importing/exporting and changing reiterations.  All the files align nicely, but we really want to move the origin for reference to our designated intersection.  Though we've set that in Revit and CAD and they work, importing them into Navisworks puts the origin thousands of miles off to the left.  Anybody know how I could fix this? Thanks!
Tags (2)
3 REPLIES 3
Logos_Atum
in reply to: k.lew
Hello there,
I just managed to move the coordinate systems for each part individually,
not unlike moving the Gizmos in Max. Sadly this is not very versaitle and,
as far as I know, it´s not permanent. Therefore the transform handles
sometimes are a little out of place, therefore it´s zoom versus position of
handles.
Therefore I imported all of the parts - placed them- deleted them one by
one and saved each and every part as a new nwf long with it´s coordinates
relative to the other parts.
A little complicated, but it did the job. Is that something in the way you de-
sired to do?
Kind regards
Daneil
Dogs aren´t flammable.
k.lew
in reply to: Logos_Atum
Yikes...not experienced in Max either, but sounds really difficult.
Probably not what I'm looking for.
Essentially I'm exporting Navisworks to an fbx to be imported into Infraworks, and the origin is so far out that it's incredibly difficult. But I want the Revit references to remain, so I can still swap out models (importing Revit nwc into Navisworks) and then the Navisworks origin to also remain, but move closer, because that's the origin Infraworks uses.
For now, I've settled for exporting the fbx and importing the fbx into a new Navisworks, moving it a set distance closer to the origin and then re-exporting. Sigh...
Logos_Atum
in reply to: k.lew
Well that sound like a hell lot of fun 🙂
I never managed to move the center
to more desirable coordinates perma-
nently. So I ended up doing quite the
same.
Was fun, especially if the input units
differ by 1000 (mm to m) and you need
to make a meaningful combination of
both.
Good luck 🙂
Kind regards
Daniel
Rail Community
