Anyone:
We are running clash detection on two .NWC files exported from Revit MEP 2013. The pipe and ductwork all have actual insulation installed in Revit (with varying thicknesses, depending on pipe system), but the steel doesn't show fireproofing. We can't just use a global tolerance distance, instead we must add a 1-1/2" tolerance to ONLY the structural steel, in order for our clash detection to work properly.
Does anyone have any suggestions?
We actually modelled the fireproofing with 2" "plates" and had to chamfer corners. I actually did it in a non-Autodesk software with a component all set up so that I could just apply it to the steel beams... a lot of work but no real work around.
The other thing I tried was to "Animate" the steel beams that were fireproofed to move 2" (or whatever the fireprotection thickness is) in every direction and run the clash detection with the animation linked to it... got varying results and both methods are cumbersome, but it got the job done.
Hope it helps.
Fireproofing is rendering somethin proof against fire, or incombustible; or material for use in making anything fire-proof.
