Revit 2014 Model Lines are not visible in Navisworks? How to make them visible? It's for our tile setting out coordination use.
Solved by sureshchotrani. Go to Solution.
Due to changes in how the model is exported from Revit 2014, these lines are no longer output.
Our developers have been made aware that this change in behavior impairs certain workflows, and they are looking into changing this in a future release.
If you would like to submit your feedback directly to our developers on how this change affects your use of Revit/Navisworks, you can use the following link:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
There is work around for this, just export whatever you have model in model lines in dwg and append the same in Navisworks.
This way you can see the model lines.
Remember to switch onn the lines in Navisworks else you will not be able to see dwg file appended.
