I create an NWF file in Navisworks 2013 with 2 RVT files in a note book. When I open the same file in a desktop computer the model is not displayed. Does anyone have an idea why?
Claudia Campos
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão 'Aceitar Solução ' .
Claudia Campos
Comunidade de Usuários Autodesk Português - Coordenadora
Check the paths. Assuming the files are on a server, is the server location mapped the same way in both computers?
Hello!
Thanks for the prompt answer but I found the problem.
The Revit files didn´t use Shared Coordinates in this project as usual for me. It was using Project base Point, so in Navisworks I had to set RVT files to import using Project Internal!
Claudia
Claudia Campos
