I have a coordination model that I have used through the project for aprox 6 months and recently updated Navisworks to 2014. When I did this update one of my appended models began to come in in the wrong location and not to scale. I reviewed the Autocad file and nothing has changed on that end. I can not find a setting in autodesk that could have been set back to default with the update. Anyone ever have this happen?
Solved by stahci. Go to Solution.
Wow well my brain wasnt firing on all cylinders.... the issues was with the units in Navisworks and why they got reset with the update I am not sure. Simply select the model and right click-> Units and Transform-> change file units. Boom problem solved
