I keep getting memory msgs that crash me. ANy suggestions for settings?
Solved by DarrenP. Go to Solution.
2014 with SP1 ?
I read in the document something about the mem limit was fixed with SP1.
i have it posted here:
http://forums.autodesk.com/t5/Autodesk-Navisworks/NavisWorks-2014-SP1-is-out/td-p/4335454
i ran into a problem when it was installed
DarrenP
yep thats exactly what happened to me also
DarrenP
alright i am making sure its not a windows 8 issue which is what i am using
DarrenP
i also installed navisworks from factory design ultimate 2014
DarrenP
you can't uninstall the service pack without uninstalling navisworks
DarrenP
i have a case open with autodesk
i will let you know what they find out
DarrenP
this seems to only effect navisworks from the factory design suite 2014
i tested the service pack on a non suite version of navisworks 2014
and navisworks from the building design suite 2014 the crash does not happen
DarrenP
Good to know, Darren. Thanks for the followup....now to Autodesk, when is there gonna be a service pack for the service pack for FDSU?
the case i have with autodesk is still open
i told them my findings
i am waiting on them for an answer
DarrenP
i heard back from them
Thank you for bringing this issue to our attention. I have documented and submitted
your case to our development team for further investigation.
The case will be updated as soon as I hear back from them.
DarrenP
the fix is out: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21985761&linkID=16831210
DarrenP
this hotfix worked for me
DarrenP
