Hello there,
I think it´s a bit odd that I need to import Inbventor files to showcase in order to keep the materials as they ought to be.
How? I export a FBX file out of Showcase which I open in Navisworks.
The really hard part is that I can´t run a animated construcion sequence from this file because the FBX container is one
level to deep spoken of the hierarchy to automatically add a timeliner sequence.
One way to get the animation and another to get the materials? That leaves me with two questions....
1. How to reorganize the selection hierarchy in order to automatically assign Time liner activities?
2. How to get Navisworks to import materials from Inventor files as proper as Navisworks files?
The attached picture shows the finished import to Navisworks-
FBX from Inventor via Showcase
And IAM Import directly from Inventor
Any suggestions?
Kind regards
Daniel
Correction
I should be reading my posts more carefull...
2. How to get Navisworks to import materials from Inventor files as proper as Showcase FBX files?
Could some Autodesk official kindly add some hint how to solve to this topic or is it impossible without heavy manual work?
I need a silk road to Navisworks...I tried multiple programs, tools and converters- it just won´t work...
The problem is as in the picture attached...
Is changing the structure that hard? Do I need the SDK? The quality improvement and the reduction in post import work would
be tremendous...
Kind regards
Daniel
