Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Material volume show in simulation
2 REPLIES 2
BIMAbhi
672 Views, 2 Replies
Can we show the material volume with navisworks time linear simulation in according to duration (daywise)
Thanks & Regards
BIMAbhi
2 REPLIES 2
lee.mullin
in reply to: BIMAbhi
Do you mean as in the actual volume of Material Excavated for example?
It isn't possible to show this but you can go into the settings and Add the task name and percentage of the task complete, which you can show under the date
Go to Overlay Text > Edit, select where you would like the Task name to go (Ctrl +Enter if on the next line) > Extras > Currently Active Tasks
This is obviously a sample image model but hopefully you get the idea.
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
lita_kusriyani
in reply to: lee.mullin
Can I change that progress percentage to be volume
Rail Community
