I was really excited about the abilty to open up Revit files in Navisworks. I am having a problem with this feature. When i append models, they are not coming in to the correct location. In Revit, shared coordinates were used. I can export from Revit to an NWC and append in Navis and everything comes in fine. I just can't get the seperate Revit models to line up in Navisworks. Any ideas?
Have you checked for Options>File Readers>Revit settings? There is an option in there for Coordinates that I believe is defaulted to "Project Internal". I changed mine to "Shared". Hope this helps.
Robert Androse Glover, bSa
BIM Project Coordinator, Project Designer
Wiley|Wilson
6606 West Broad Street, Suite 500
Richmond, VA 23230-1717
804.254.6686
Autodesk Revit Architecture 2013 Certified Professional
Autodesk 3ds Max Design 2011 Certified Professional
