5 large native inventor assemblies in my current navisworks file. It takes well over a half hour to open this file. I have approximate 5 more of these large files that I need to append into my navisworks model but the file is getting to big. I am using a .nwf file and navisworks simulate. Any suggestions on options to change to optimize my file?
Thanks!
Solved by Patrick_Aps_9121. Go to Solution.
Is read and write cache files enabled? ie. are you loading the source data every time or the NWC files?
Are parts changing frequently? If not, then consider publishing the more static pieces in NWD format and using those.
Anything being pulled directly from Vault or other EDMS? Or over a WAN or remote connection? Ensure everything is accessed over the fastest possible connection (which may be a local copy).
Not sure about how duplicates are handled through loading Inventor files. Ensure that you aren't loading multiple copies of the same objects when you only need one.
yes I have read and write cache files enabled. My parts are changing hourly so I feel like making a static file would leave the model too out of date. I was hoping there was something I could do in NW to make the .iam file work. I am pulling the files off our server with a WAN connection. We do not use vault or any file keeping programs. and I think saving a local file instead of using the file on the server would be the same as creating a static file.
Should I turn off read and write cache file?
Help?!?
Thanks!
Excellent synopsis. We do something similar with a massive database-driven project. I'd also sit with your IT and see if there is any WAN optimization they can assist with.
