Navisworks Forum
Welcome to Autodeskā€™s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Integration BIM 360 and Nawisworks 2015
5 REPLIES 5
358 Views, 5 Replies
I can not upload my model from navisworks 2015 into cloud (BIM 360)
should I inistall BIM 360 plugin for Navisworks 2015?
Or should be a toolbar which is called BIM 360 in Navisworks 2015?!
http://beyonddesign.typepad.com/posts/2014/03/connecting-the-dots-2015-product-launch-and-bim-360.ht...)
but I can not find any toolbar which is called BIM 360!
and I can not find any BIM 360 plugin which support NV 2015!
Thanks for your help,
regards
5 REPLIES 5
DarrenP
in reply to: 2776167
it should be a ribbon tab in the autodesk products not a toolbar
BIM 360 Glue isn't free
so if you are not paying for the service then you cannot upload anything to it
DarrenP
in reply to: DarrenP
Thanks Darren
The company which I am working for, has paied for it so I have the right to use the services.
but I do not have any ribbon tab in my NV 2015!
I have attached a pic from it.
my NV is unregistered(30 days trial)
could it be a reason for that?
Milad
DarrenP
do you remember unselecting the BIM 360 add in during installation?
DarrenP
DarrenP
try re running the installation again and select the BIM 360 Glue add in
DarrenP
Thanks Darren,
I am going to reinstall it and I will write about the result
my regards
Milad
Rail Community
Ā
Ā
