Navisworks General Discussion
Active Member
0 Kudos
Post 1 of 6
Integration BIM 360 and Nawisworks 2015
183 Views, 5 Replies
04-02-2014 07:20 AM
I can not upload my model from navisworks 2015 into cloud (BIM 360)
should I inistall BIM 360 plugin for Navisworks 2015?
Or should be a toolbar which is called BIM 360 in Navisworks 2015?!
http://beyonddesign.typepad.com/posts/2014/03/connecting-the-dots-2015-product-launch-and-bim-360.ht...)
but I can not find any toolbar which is called BIM 360!
and I can not find any BIM 360 plugin which support NV 2015!
Thanks for your help,
regards
657 Kudos
Post 2 of 6
Re: Integration BIM 360 and Nawisworks 2015
04-02-2014 08:26 AM in reply to: 2776167
it should be a ribbon tab in the autodesk products not a toolbar
BIM 360 Glue isn't free
so if you are not paying for the service then you cannot upload anything to it
Active Member
0 Kudos
Post 3 of 6
04-02-2014 10:45 PM in reply to: DarrenP
Thanks Darren
The company which I am working for, has paied for it so I have the right to use the services.
but I do not have any ribbon tab in my NV 2015!
I have attached a pic from it.
my NV is unregistered(30 days trial)
could it be a reason for that?
Milad
657 Kudos
Post 4 of 6
04-03-2014 08:15 AM in reply to: 2776167
do you remember unselecting the BIM 360 add in during installation?
657 Kudos
Post 5 of 6
04-03-2014 08:19 AM in reply to: DarrenP
try re running the installation again and select the BIM 360 Glue add in
Active Member
0 Kudos
Post 6 of 6
04-03-2014 11:38 PM in reply to: DarrenP
Thanks Darren,
I am going to reinstall it and I will write about the result
my regards
Milad
Have API Questions?
New Dedicated Forum for Navisworks API
