When trying to install Navisworks Freedom 2011 viewer I get the following error. "Cannot update some system component now. Please reboot machine and try again" I have tried just about everything I can think of with no luck.
Yes I have admin rights.
Checked and even manually set the file/folder permissions.
Rebooted.
Re downloaded.
Even tried in safe mode.
I am stumped at the moment has anyone seen this error?
Thanks.
It probably will have to do with the "prerequisite software" like .NET runtime or XMLparser or so.
I solved this issue by downloading the "prerequisites" that are needed to run a MicroStation V8i and installing those first.
After that and a reboot; try again.
P.s. You're not trying to install the 32-bit version on a 64-bits Windows, are you ?
Please refer the solution on Autodesk.com entitled "2011: Error installing SP1". This should help resolve your issue.
