I am getting inconsistent counting when using the Selection Box tool to select rooms in my NWF.
I have just one nwc in the file. I have used the find tool (item - type - equals - rooms) and it selects 1100 rooms.
But when i use the selection tool it i select about half the building if find 600 rooms as expected but when i select the whole building it finds only 32 items.
Is anyone else getting this strange counting?
I have tried all types of selection - left to right - right to left - with shift - and all selectrion resolutions.
Johnny
Please respond to the following:
1. Are all users getting the same results in this file?
2. If you re-export and try the selection tool again what happens?
3. If you count the rooms in Revit how many do you have?
4. Did you ever get the expected results (in other words it worked before but not now)?
Thanks for posting,
I have just added the latest update to Navisworks and download new models, ill test again soon and see what results i get.
Yes, but were using same models and same navisworks Build.
Will let you now with lastest test.
the room Count in Revit Matches the find tool with 1100
No
