In Navisworks how can we see the Pipe tag, Instrument tag & Elevation, Co-ordinates for a particular equipment etc.
Thank you for your posting. Currently tags and spot elevations are not exported. Please use to the link below and submit your request to the project manager of Navisworks:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
For exporting grids and levels, please refer to the following link:
http://beyonddesign.typepad.com/posts/2012/03/navisworks-2013-revit-grids-and-levels-support.html
Regarding Revit model export to Navisworks, please refer to this:
http://wikihelp.autodesk.com/Revit/enu/Community/Tips_and_Tricks/Import,_Export,_Layers
Hope it helps.
mext is supported however
in options select
file readers
check box next to convert text
