Navisworks General Discussion
massimocacopardo1358
Message 1 of 9 (469 Views)
Improving graphics
469 Views, 8 Replies
02-17-2014 05:58 AM
it is possible to improve the general graphics of a NWD model? In 'attached picture you can see how shapes appear very edgy, especially piping and cylindrical shapes.
Thank you so much.
Navisworks doesn't do curves, it converts everything to triangular faces.  So at some level you will always have that appearance.  You can reduce their look with the Faceting factor and Max Facet Deviation settings under Options (read the help *first* so you understand what these do).  "Better" settings will come with a performance hit, so sometimes its necessary to suck it up and live with marginal graphics to accomodate fast file opening and zipping around the model.
And all that assumes the source objects aren't actually faceted to begin with.
New Member
anthony.kamil
Message 2 of 9 (456 Views)
Re: Improving graphics
02-17-2014 06:21 AM in reply to: massimocacopardo1358
have you tried to change the render style?
within Navisworks?
Anthony
Valued Mentor
Logos_Atum
Message 3 of 9 (454 Views)
Betreff: Improving graphics
02-17-2014 06:28 AM in reply to: massimocacopardo1358
Hello there,
for the viewport you would want to increase the MSAA level to 32 or 64.
At least this is possible for Autodesk graphics. Which dsiplay mode are you
using? There are some options you can tweak the appearance by. LOD tex-
tures and the general texture resolution too.
I´d also turn off software render support and stick with hardware rendering.
Which one is it? Presenter or Autodesk rendering?
Kind regards
Daniel
- 2500K @ 4.2Ghz- 8GB - Radeon7970 -
- Xeon 1230V2 @ stock Ghz- 32GB - W7000-
- 2x Xeon 2670V2 - 64GB - W7000 - 4x Quadro 2000 - oh yes -
- Factory Design Suite Premium Subscription-
Message 4 of 9 (444 Views)
02-17-2014 08:00 AM in reply to: anthony.kamil
It isn't a render but a screen shot of normal 3d navigation of NavisWork. I need to know what setting tap to improve the graphics.
Valued Mentor
Logos_Atum
Message 5 of 9 (424 Views)
02-17-2014 11:33 PM in reply to: massimocacopardo1358
Hello there,
that´s understood. There are two systems in Navisworks that allow you to preview and review models
and they are running soley on the graphics card -  Presenter and Autodesk rendering. Both of them can
be used for displaying. Dependent on the model (Textures, materials...) they differ. Both come with a num-
ber of settings that can improve the overall display quality.
I´ve attached the corresponding "Options" Tab - even though in German, it might prove helpful to you.
The differences of Autodesk and Presenter graphics are resting in material handling and diplaying them.
While one can display high res textures embedded in FBX files (Presenter) the other one (Autodesk) won´t
be displaying them at all, it will allow you to assign Autodesk materials.
There are numerous points wherin they differ, just choose the one that gives you the most decent look while
delivering the performance you need.
Ah... setting MSAA to 64 will get rid of the AA lines of the objects. If in doubt test the settings in a seperate
file. Some of them will require a restart, therefore take your time :smileyhappy:
Kind regards
Daniel
dgorsman
Message 6 of 9 (409 Views)
02-18-2014 07:43 AM in reply to: massimocacopardo1358
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Message 7 of 9 (403 Views)
02-18-2014 07:58 AM in reply to: Logos_Atum
I tried to set Naviswork as in the attached image, but nothing changes. The 3D models created with Plant 3D are all displayed in this way.
Message 8 of 9 (394 Views)
02-18-2014 08:32 AM in reply to: dgorsman
We must increase the faceting factor (see attached pictures). Options, File Readers, DWG / DXF.
thanks
Valued Mentor
Logos_Atum
Message 9 of 9 (367 Views)
02-19-2014 06:21 AM in reply to: massimocacopardo1358
Ah - never thought of that outside of AutoCAD.
Quite simple if you know it applies to the import
options in Navisworks too....
Kind regards
Daniel
Have API Questions?
New Dedicated Forum for Navisworks API
