We have a tool where we can import the Clash Reports (XML + jpg's) into Revit to solve our clashes.
In this tool we can also change the status and add comments to every clashresult.
Is there a possibility to import tha ClashReport-XML back into Navisworks (NWD) ?
Or are there tools you who can facilitate this ?
Thanks.
I am facing a similar problem. I want to export the clash report in xml format, import it into excel. When i am trying to do this, i have to go ahead with excel default schema (is there a better option?)
I am then going to make all the changes in the excel file -> convert it back to xml -> import it to navisworks manage.
This is mainly because i want multiple users to work on navisworks .nwf file at the same time. Since that is not posssible, i can make the excel clash report shared, and then import the final report back to navisworks.
Sachin
Since I have no knowledge of the Navisworks API I cannot judge the possibility to import the clash results.
But I have a feeling that it won't be possible, because it is against the "Autodesk Workflow"...
