Hi everyone,
I'm trying to import FLS files into Navisworks 2014 Manage SP1.
The error states it does not exist or can't be opened.
I searched the forum and saw it has been asked before, but not for this release, so i hope someone can help me out.
(The FLS files are created with a X130, and postprocessed in Scene 5.3)
Thanks in advance,
Kind regards,
Roy
Hi Patrick,
I replaced the dll's you mentioned and tried to register but unfortunately that fails.
I tried it this way:
Command prompt with admin rights:
regsvr32 "C:\Program Files\Autodesk\Navisworks Manage 2014\iqopen.dll"
Any suggestions maybe?
Thanks for the reply, i appreciate it:-)
Roy
Did you unregister first ?
Does none of the DLL's register ? Maybe it's a matter of registering them in the right order.
Maybe my list of DLL files is not complete and there is a dll missing. Check the properties, detail tab of all files in C:\Program Files\Autodesk\Navisworks Manage 2014 that have the same time and date (27 nov 2012 6h54) to see if they have copyright of Faro and version 5.1 or 5.3...
I found LSBase.dll and LSlib2.dll also to be from Faro.
I did this job years ago with Simulate 2011 and got it working, but not with more recent versions.
Use ReCap to process the point cloud then load the ReCap file into Navisworks.
@Patrick, i tried the unregistering first, but no results. The new dll won't register.
I'll see if our IT department has more luck with it.
@dgorsman Thats the way i currently do it. I import the FLS files in RECAP, convert them into RCS and use those in Navisworks.
Although that works okay, i want to use the FLS directly in Navisworks because it saves the time of the conversion, and i'm curious if the quality is better that way.
Roy
The only thing left would be asking with Faro Support to see if you can get a copy of the files they would deliver to Autodesk to support 5.3 in a future version of Navisworks.
