Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Import hyperlink from file
2 REPLIES 2
327 Views, 2 Replies
In my model I have alot of pipes. These pipes have an isometric-drawing which is placed on a network-drive.
Can I somehow make a txt-file with pipenumber/name and tell Navisworks where the file is placed, and then it automaticlly makes the hyperlink inside Navisworks.
If I should make it manually it would take forever.
Is it possible to import this hyperlink-file in some way?
Regards
2 REPLIES 2
You could use Navistools to set up the link and read in linked file name from spreadsheet and then stored in model and published so you also have the links in Freedom
Edited by
Discussion_Admin
Hi John.
Thanks for the link. I did not know about theis program.
I will give it a try. If it can do what you described, by adding a link from a spreadsheet it would be perfect.
Regards.
Rail Community
