I am currently using Navisworks Simulate 2014.
When I export an image using Viewport as the Render, the grid lines will show. Refer to viewport - grids show.png. However, the resolution of the image at 2048 by 1024 is not sufficient, i.e. when I scroll in, the objects will be pixelated. Since the maximum size for the export is only 2048 by 2048, I tried using the Rendered Image option.
When exporting an imagine using the Rendered Image, I can increased the size to 4096 by 2048 and the objects appear better when scrolling in. Refer to rendered image - grids not showing.png. However, now the grids do not appear in the render. Is it possible to export the rendered image with the grids? Or does anyone have an alternative workaround?
Perhaps a dumb workaround, but extrude your grid lines to small tubes and your labels to 3Dtexts
and youi might need to assign a material to them.
That's a good suggestion. However, I was hoping I could avoid this situation since it will be quite tedious to extrude all the texts.
On top of that, I might have to make a few/multiple angles to account for different view angles.
Nevertheless, I will give it a try if there's no other options. Hopefully such a simple functionality can be included in the next Navisworks version.
