Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
How to set background color and settings in a batch (command line) mode?
1 REPLY 1
Abbas-Ali
802 Views, 1 Reply
How to set background color & settings in a batch (command line) mode?
1 REPLY 1
JeffH_ADSK
in reply to: Abbas-Ali
Provided the settings are available as global options, you should be able to specify specific options as XML and then load them on the command line using the argument -options. Defining the options as you prefer in the Navisworks Global Options and then exporting them as XML should give you a suitable starting point.
Hope that helps,
Jeff
Senior Software Engineer
Navisworks
Autodesk Ltd.
Rail Community
