Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
How to Quantify the differences in Compared models
2 REPLIES 2
LisaDrago
1012 Views, 2 Replies
Hello - I have a client working with Navisworks and has asked me a couple of questions:
1. In comparing models - how can he see the differences between the old and the new. Get the actual calculations. For instance in a foundation plan - if the footing and structural wall requiring concrete - by how much did it change?
2. When comparing models - the elements that have not changed are not hiding when we check it in the dialog box. Nothing really highlights when we run the compare command. The elements can be selected from the sets that were created. But it does not seem to be working correctly.
Any thoughts?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
2 REPLIES 2
danielkazado
in reply to: LisaDrago
Dear Lisa,
  I faced the same issue before, could you please check under Viewport - Render Style the display mode is Shaded. If you select Full Render before Compare it does not show up any virtual result. Before Compare run you shall shift to Shaded view. Hope helps.
Daniel Kazado
Please use Accept as Solution if your question is answered.
You may Give Kudos if the answer is helpful.
LisaDrago
in reply to: danielkazado
Thank you - this did fix the display issue.
LD
Rail Community
